I find that selecting things on the screen to either be sluggish or perhaps simply hard to select .
Grabbing a fader seems to ok.
Clicking a mix button is all but impossible. I don’t think I can use the iPad to make monitor mix adjustments in a live situation.
My iPad is a generation 4 64gb so it ISP as fast as they come.
It works perfect with Stagemix on my LS9
rob at lynxaudioservices dot com
Hi Rob!
Well, you can’t click at a Mix button! You have to double click on the AUX or Input Channel you would like to set as “MIX”! To Activate a Channel for Channelstrip assignment just klick once on a Channel!
If you know where exactli you have to click, then it’s easy and you can use it fast and without wrong clicks in live situations!
Cheers eotsskleet
GLD-80 / AR2412 / AR84 / Qu-16
I actually found it quite easy to use. No problem double tapping a monitor send to mix double tapping an instrument to adjust on the monitor sends. I adjusted everyone’s mixes from behind the drummer (I’m the drum we lol) and no probs whatsoever. I did have a band member who always had trouble using both the iPad and the GPS touch screen though…
Blush.
I should have RTFM.
I was trying to click on the little mix button.
Much better now.
Next week I will update to 1.3 and install the editor.
I hope they do a ducker next update.
