Hello fellas - I used an IEM setup recently with my QU-32 and had trouble getting the volume up. It also seemed like the louder I pushed it - the more “Squashed” it made everything.
I did not use a headphone amp. I went straight out of a stereo Aux into my IEM unit. Unit receiver was up all the way and transmitter pack was up all the way.
Is it typically necessary to use a headphone amp with in-ears?
Ok. I use an Galaxy Audio AS-900 unit. I ran out of stereo aux on QU-32 hard wired into AS-900 Receiver.
From receiver to transmitter I went wireless into a set of Shure SE-215 earbuds.
I have a headphone amp (Presonus HP-60) that I could use but was wondering if it is necessary with the QU-32. Trying to simplify and downsize any extra gear as much as possible…
Dr. J, read the manual for the Galaxy Audio AS-900 and see if it has a compressor/limiter built in. I think most IEM units have that built in anyway. That would account for the squashed sound you get as you bring up the volume.
As for the volume problem it sounds to me like the channel levels of your mix to your IEMs are not loud enough and you are pushing the volume to make up for that. Push the channel levels louder in the mix you’ve chosen for your IEM mix and see if that gives you the volume you need.
