Is IT possible,that the complete A&H Website does Not have a single hint what the Name of the DAW was, that could sync names with their mixers?
Best Regards,
Tobias
If you’ve forgotten, it’s Harrison LiveTrax.
As has been said, the DAW is Harrison LiveTrax
But actually pulling the channels names from your mixer is not exactly intuitive…
  1. Create a new recording session.
  2. It will then ask you how many tracks you want to record. Confirm this
  3. Now you have all the tracks, but they’re unlabelled
  4. Click on the gear icon in the top right
  5. Select Control Surfaces, then check the box for your mixer type
  6. Press the configuration button that now appears next to the text “Edit the settings for selected protocol”
  7. In the pop-up window, select “Accept channel names from mixer”
  8. Now press “Request ALL channel names from mixer”
Harrison LiveTrax is mentioned/linked at the bottom of the webpage for every compatible product - LiveTrax
There’s more info on setup and use of it with A&H consoles here - https://support.allen-heath.com/hc/en-gb/articles/26667597200657-Using-Harrison-LiveTrax-with-Allen-Heath-consoles
