Is there a copy a Mix bus contributions to another Mix Bus
I’m looking to copy all the channel contributions from one mix bus to the next. Will speed up monitor worlds dialing.
Is there such a thing on the SQ console yet?
Hey Haniel,
Sure! Just use the Copy/Paste keys along with the Mix keys as here - (https://youtu.be/kKE1gThSTrw?t=28)
You can also use the Reset key, but obviously go careful with that one!
Cheers,
is it possible to copy/paste/reset a single channel routing?
processing is easy… but routing…
Hi Steffen,
I don´t think so, but you can use ganging as a work around. The first memeber of a group will determine the how the attributes change. As soon as you hit apply the routing (providing you marked the little routing rectangle) is copied from member one to all others.
Cheers,
Andre
I know that with ganging already
but I’m not in front of a console so I can’t check if it’s possible to copy routings
@Steffen R,
Currently, use of Copy/Paste/Reset for routing is from the mix point of view only. So you cannot use Copy/Paste/Reset for individual channels, but can use them for entire mixes.
There has been some discussion, but very few requests for Copy/Paste/Reset for single channel routing.
Cheers,
