Issue with the bank Selecting Switches
I am facing an issue with my iLive-T112 with IDR 48. The right end bank selecting switch is not functioning normally. Some time after a boot-up it will work normally. If I press ‘Bank A’ nothing will select, if it is in other Bank. But if I press Bank A and Bank B switches simultaneously, then Bank A will select. If I press Bank C and Bank B switches simultaneously it will select Bank B.If I want to select Bank D, then I have to press Bank D and bottom ‘GO’ switch. I feel its a minor hardware issue or some time software. Do anyone give me some solution for this if you faced similar issue with the mixer. If we linked all the banks it will works normally with the other two sets of Bank selecting switched on the left and center of the mixer.
