iTweak security hole.
Our configuration is designed so we have a number of logins for the T112/iDR64 including a “basic” setup for less familiar engineers.
This login has no password which brings me to iTweak.
If I log into Tweak using the Basic login, I can still see ALL the stuff a full access login can see esp MIX EQ and levels.
admittedly, a rogue user would still have to break into the wireless connection but it still feels like a bit of a security hole.
cheers,
Duncan Whitcombe
Mirror Sounds & metrochurch
Perth, Australia
T112, iDR48x2, Dante soon
www.mirrorsounds.com.au
www.metrochurch.org.au
Security hole agreed! You could also use MAC address filtering on your router if you wanted to make sure no uninvited people hook up to play with your mix! I also have a no password iLive login - mainly because it’s a PITA with tweak to have to password login every time ipod touch has gone to sleep/ woken up. MAC filtering solves the problem and gives an improved security level by rejecting all unknown network devices.
Cheers
Richard Howey
Audio Dynamite Ltd
IDR48/IDR16/T112/R72
We are of two minds about security. We have a wireless access point with password protection, and then the iDR with password, but I also find it a PITA when I want to administer from my iPhone, because iTweak doesn’t multi-task, at least not on iPhone 3GS running 4.1 software, which means I have to tap in the password each time.
The question I ask myself: is it likely that an audience member is going to have the nouse to download iTweak, break through the wireless AP and then log on to the iDR and f*ck around?
I think the answer is that it’s highly unlikely.
I don’t want to go to the trouble of entering MAC addresses, although that’s the most secure solution.
I hope the new iPad app has some more custom functionality for different users; apart from the security issue (‘basic’ logons having too much functionality), it would be good to have a custom screen for the sound engineer to access when moving around the venue.
www.pianojam.nl
I agree as well, especially with the iPad app.
My system is setup at a school in our performance venue we maintain. 3 times a week (soon to be 5) its a classroom.
My hope with the iPad app and eventually for iTweak is that I can setup logins on a individual basis that allows each faculty to recall scenes and adjust the necessary levels, but while maintaining the important stuff.
I would think with the way A&H markets this stuff, at least over here, to churches and the like that this would be a rather easy and HUGELY valuable feature set to address and improve.
I am also looking for a lot more expanded ACE accessory line (this January?), but that can be another thread.
Stephen Tyler
Coordinator of Technical Operations
ACM@UCO
www.acm-uco.com
iLive T-112/iDR-32; T-80/iDR-16; iPhone; iPad (soon)
