The Harrison Mixbus will not start under Dante under Windows 7. (A different program will - on the same Win7.) And the Harrison Mixbus works on a different machine (XP and AVLinux, but of course the Dante doesn’t work) so I’m puzzled.
Win 7 Pro
Session Control
Audio Setup
Driver: Audio Devices
Output device: Dante Virtual Soundcard [ASIO]
Input device: Dante Virtual Soundcard [ASIO]
Sample Rate: 48000Hz
Buffer size: 256
Approximate latency 10.7msec
(more stuff)
Quit — Clear — Start Audio Engine
then…
Mixbus could not start JACK
There are several reasons:
- You requested audio parameters that are not supported…
- JACK is running as another user.
Please consider the possibilities, and perhaps try different parameters.
You may need to force-quit a currently running instance of JACK.
OK
How?
