feel free to add details.
Download Photo/File: ilive-dante.pdf
101.12 KB
IDR48 & T112, QU16, AR2412 , Dante, Lenovo i5, Samplitude ProX, Pro Tools11
101.12 KB
Another small tipp:
About ticks while recording…
Try these steps
a) raise latency stepwise from 4, 6 to 10ms - getting better ? even gone? no - then next
b) lower samplingrate from 48k to 44.1 (less data) - better - gone? - no - then check connection speed again, use CAT5e or higher to get 1GB connection… still ticks ?
c) reduce channels for recording if possible…still ticks?
This can have several reasons. Especially in Windows based systems (Laptops) they usually use a build-in HD with only 5600 rpm. This and a low internal data transfer rate can cause the issue. Also a fragmented drive could be a problem.
Apple systems usually use HDs with 7200 rpm, so they naturally have a higher internal data rate.
These ticks cuased from the internal write-buffer, while writing the streamed data from dante to your harddrive. Anything that hepls to lower the data rate could help. f.e. Stop your AntiVirusSoftware task!!! or any kind of pre-started software that additionally needs the drive permanently or even sometimes. (Dropbox, any anti-malware, harddrive monitoring …)
Check fragmentation of your harddrive - check for bad sectors.
pls feel free to add more tipps and tricks …
still ticks and crackles while recording ?
Check the Sync Slave setting!
If the Dante slave port is not connected, the checkbox must be set to sync the slave port with the wordclock signal.
thanks to Bernd
