Is there a way I can connect a mouse and keyboard to control maybe something like my 3rd screen or even the screens on the cosnole itself instead of touching the screens?
Thanks.
Thanks.
I’ve connected a keyboard and used it to name inputs and outputs. Couldn’t get anything out of a mouse. I think that the mouse is useful on the externally connected screen.
That is strange, I’m using mouse without any trouble.
ddff
A USB keyboard should work if you plug into the rear USB port or the ‘Data’ USB port on the front of the console. A USB mouse will also connect. To view the mouse pointer, press F11 on your USB keyboard after startup.
Where is your mouse connected to, if you don’t mind me asking?
Thanks.
I’ll try that tomorrow when I’m back on site. I currently have my keyboard connected to the usb port on the back. I’ll connect the mouse to the USB data port and see if that works.
Ideally, it would nice to have an extra port for the USB mouse so in case I need to transfer datas during a show, one is having to unplug things out of the usb ports.
Thanks for the tip though. Will try that tomorrow and see how it works for me.
I think I had my keyboard in the front and mouse in the back.
I am using a wireless keyboard with built in track pad connected to the back data port. The keyboard works fine. When I press F11, 2 cursors show up on the right screen. 1 moves with the trackpad and the other I can move with my finger I n the screen. Is this normal? The second question, does the mouse only work on the right screen? If not how do you get it to go to the left screen.
