Hi All,
The SQ’s USB interface offers 32x32 channels at 96kHz, this is no small feat, especially when it is only one part of the system as a whole. I would therefore suggest it is an unfair comparison to put the SQ next to a dedicated interface when comparing latency (especially as some models from the manufacturers mentioned here which have the same channel count are around 50% of the cost of the whole SQ!).
Saying that, the latency does not make the USB port unusable, and we even have people using it for inserting time critical channel processing in a live environment, which is something that we would not generally recommend… but as has already been pointed out, the computer is by far the biggest variable in a system utilising the USB connection.
It is well known that the latency of the SQ itself is extremely low - less than 0.7ms from analogue input to analogue output. One of the reasons this is so desirable by engineers is because the SQ may only be part of a whole system of devices that all add their own latency (radio microphones, IEM packs, system processors etc…). So we definitely understand the need for low latency, and have provided multiple options for internal and external processing so you can get exactly what you need. Here’s a quick overview:
USB-B: 32x32 channel, 96kHz, great for use with a DAW for recording or playback, also useful for non-time-critical processing such as reverbs and delays, carries MIDI, class compliant on Mac, requires nothing more than a USB cable to connect to a computer.
DEEP plugins: High end modelling of classic processors from our flagship range, insertable directly in the channel, zero added latency (so still less than 0.7ms input to output, and phase coherent), no extra cables or equipment, compressors can be used in place of any stock compressor, GEQ’s used in place of any stock GEQ, Preamp can be used on every input channel.
Waves option card: 64x64 channel 96/48kHz, provides connection to other Waves SoundGrid equipment, can be connected to a computer running the virtual sound card with latency dependant on system (but generally lower than USB), connect to Waves servers (these are heavily customised PC’s with Waves drivers that offer much lower latency than a standard computer).
Dante option card: 64x64 channel 96/48kHz, connect to any Dante network, can be connected to Dante Virtual Soundcard on a computer (adds latency, 64x64@48kHz, 32x32@96kHz), low latency options via PCIe cards, great for recording at higher channel count and interoperability between thousands of different pieces of equipment.
So it just depends on your requirements.
Cheers,
