When I save channels to the user library, example (Kick), when I load the preset into ch.1
the title and color is not entered on the scribble strip. This should be included along with the
preamp settings. Also when copy and paste is used no title and color is copied to the scribble strip.
This makes setting up new layers time consuming by having to title every channel again. Coming from
the Midas M32 this one of the most missed features.
Yes please!
Oh well…
if you have a guitar preset and you have 4 guitars they all become the same name…
if you have a preset for a microphone (SM58) all channels are named with the microphone…
maybe it’s better to use scenes for names and colors
This makes setting up new layers time consuming by having to title every channel again. Coming from the Midas M32 this one of the most missed features.the labeling on the X/M32 is horrible... but the naming on the SQ has nothing to do with the layers
if you have a naming sheme than you can save this in a scene and even your layer configuration is storeable in scenes
First of all, on the X/M32 you can use Naming and Icon presets for the most frequent Instruments. Only special naming might be a problem. But using a remoting app will also speed up this process. But you are right, the “text editor” of the X/M32 is really bad.
What I am missing on the SQ are the Naming Presets like we have it on GLD/dLIve even when 15 presets is quite less. I would prefer that the lower row of seven buttons represents naming groups and the upper eight buttons the names stored in the group. Or something like that. I am working with different groups with different sets of instruments (Rock, Jazz, World, classic…) and when I prefill it with the overall standards, I miss the genre specific standards.
I also miss the layout of the naming dialog of the dLive where the colors and the Keyboard is concurrently on the screen. And on the SQ I have to confirm the color change while on the dLive the color is changed when I select the new color. So, for me also here is a lot of room for improvements.
But with the new version 1.4 this problem is not that important for me because now I can use my recording notebook even in live situation to change the color and the names easily.
indeed it is
naming presets would help a lot and the dLive way is not the best…
It should be an optional save setting, so if I want to save the scribble strip, I can.
@ New2SQ, I would change that to, “It should be an optional recall setting, so if I want to recall the scribble strip, I can.”
That leaves your options open.
Perfectly said!
Hi guys,
The ability with V1.4 to name using MixPad on multiple platforms is indeed great, but nobody here seems to have checked the channel libraries… (Press library in processing bank view).
Cheers,
