Running an SQ-6 in our church and been having on-going intermittent library issues. When we push the library button we never get the same list of profiles twice. Sometimes we will get all the factory or sometimes only a few. As far as saved/custom profiles, again the same, sometimes we will get all of them displayed and sometimes only a few. When we only get a few of them, they are also random…never the same few on a screen. Along with the intermittent profile recall are the buttons to the left of the profile list…“recall name, HPF, and channel (i think)” Again, sometimes no buttons, or maybe one, rarely all three. We are running software ver 1.5.0 at the moment, with hopefully the update here when i can get to it.
Note that user libraries are stored within shows, so if you recall a show, you will see only the user libraries stored in that show.
Libraries can be stored separately to a USB device too though, meaning you can then copy them into any show!
Thanks for the input…will double check, but I am sure that we are not using scenes or shows. We are experiencing this from the default settings. We have no users/passwords programmed, no scenes, and no shows.
The note about shows and storage of libraries is an extra, to try and clarify the main point:
If you’re viewing a compressor on the screen and you press the Library key, you’ll see the compressor library.
If instead you’re viewing a PEQ on screen and you press the Library key, you’ll see the PEQ library.
Please see the link above to understand how this method applies to other screens and libraries.
Thanks so much for the info guys! I updated the firmware and doubled checked all the library settings. I think it is working as advertised now, I just need to go clean up all the trash that is in them now and start fresh!
