Limit SQ4you app users
Supposing to have a wifi access poin able to connect up to 10 users to the wifi network, the SQ4you App how many users connected at the same time is able to support?
Because I need to connect 9 tablets to the network for 9 different musicians and allow everyone to adjust their aux.
thanks.
Hi Poli84,
The SQ supports up to 8 devices at once, with up to two of these being a MixPad connection.
For example, you could have:
8 x SQ4You
2 x SQ MixPad & 6 x SQ4You
1 x SQ MixPad & 7 x SQ4You
So you could use a ME for the ninth musician, along with the 8 instances of SQ4You in your set up.
Alex
ok, so if I didn’t understand it I can have 8 users connected with the SQ4you app and one with the MixPad app at the same time, for 9 total users. it’s right?
thanks
No, max is 8 total connections including all SQ4You and Mixpad users.
Hi There.. at this time there IS a possibility to overcom the 8 apps problem:
MixAppXpander is installed on a mac, all SQ4YOU users connect VIA the MAX app and gone is the limit!
MAX is Only for mac, not tested but I guess Andoid versions of SQ4YOU and Mixpad all will run trough MAX.
Now you can :slight_smile:
