I have just purchased a Shure PSM300 IEM set and I’m wondering if there is a way to set up volume limiting on my Qu-16. I was thinking that I could use the compressor on the mix with a very high ratio. Wondering what other people are using for this?
You can do that, but I would highly recommend that you use the P3RA receiver instead of the P3R as the RA has its own limiting specifically engineered for the task.
I do have the P3RA receiver. I guess I’m just trying to be extra careful. Does it make sense to use a limiter on the mix as well as the limiter on the P3RA or is it overkill? I can imagine a situation where feedback or a spike causes the volume to jump several decibels above the normal audio. The limiter on the P3RA sets the limits of the gain/volume knob. I didn’t know if that would also hard limit the actual volume of the unit. I’m interested in other peoples experiences.
Points are well taken. The limiter on the P3RA is pretty straight forward. What had me confused is that the documentation says it limits the range of volume adjustment. That means to me that I am limiting the loudest “normal” audio peak. But if a spike occurred it could still exceed that level. I guess the trick is to keep the signal going to the transmitter as hot as possible so that even if a spike occurs it can’t exceed the physical limits of the transmitter anyway. Does that make sense?
Or maybe the proper way to gain stage this is to set the mix output to peak around 15dB (-3dBFS, just shy of full scale), set the input gain on the transmitter so that it peaks at about full scale and then set the limiter on the pack accordingly. Just talking my way through this.
The Shure manual is VERY specific about gain staging/setup. Follow their directions to the letter. Then if you need anything else, look to the Qu.
But with proper inputs ( possibly including one/two ambient mics ) and proper gain staging, you should not have to engage anything other than the IEM limiters…unless you really want to monkey with it just to see how it might work.
