linking two ilive mixers to one IDR
hello, I have two ilive mixers one is a T112 ( FOH ) the other is T48 (for monitor mix ) but with one IDR, how can I get to link them to the same IDR?
You don’t.
The IDR IS the mixer, you only have one IDR so you only have one mixer.
The T112 and I guess T80 are control surfaces, not mixers. Think of them as big expensive remote controls for the IDR, they are not mixers and without an IDR (each) they do nothing.
There is no way to attach 2 control surfaces to a single IDR MixRack.
If you wish to use what you have as a FOH/Monitor configuration you’ll need another IDR and a network card (ACE is the cheapest option although Dante gives more flexibility and functionality) in slot B of both IDRs.
The onboard ACE socket goes to the surface, the slot B interface connects the 2 MixRacks.
The good news is you don’t need another IDR the same size if you use a digital split in this way, an IDR16 will suffice.
This document shows connections using ACE.
https://www.allen-heath.com/media/Understanding-Ace-rev-18dec12.pdf
Another option would be a PC or laptop running iLive Editor software, and connected to the network.
thanks a lot for that helpful info but please elaborate more on the digital IDR 16
iLive as Monitor and Front of House System
Allen & Heath iLive Dual MixRack Setup
Allen & Heath iLive Digital Split Setup
Allen & Heath iLive MixRack Setup
Allen & Heath iLive FOH and Monitor using Surface and Editor / MixPad
M-Waves V2 now shipping
