Linux login password for GLD-80
Hello,
I’ve opened up my GLD-80 mixer, Chrome edition and connected a monitor and keyboard. The system is running Ubuntu 11.10 kernel 3.16.1.ah.2. I’m at the login screen. What is the username and password? I want to play around, maybe install an NTP update process to keep the time updated automatically.
I’m not sure if you figured this one out, but I did. I do hope mods don’t get upset about this…
I wanted to do the same thing and also fix the DST issue. I found it is due to the locale that is set.
I pulled the SSD, did a block level copy. Now I have a full image if the SSD dies. I was also able to pull the Linux Shadow file, run it through a password cracker, and got the password of “digital”. Oddly enough, I feel like I remember seeing this password somewhere on the forums a very long time ago.
I do forget what the username was. It might have just been root, but it also may have been something else. I should be able to find it if root doesn’t work.
That works. I have full access to the OS now. I installed NTP and was also able to change the hostname on the network. Very helpful!
Was it really that easy to just install NTP? I figured I’d need to change the locale because DST settings for en_GB were different or something like that.
Yes. Here are my notes I took for myself while doing it all.
The GLD-80 firmware 1.61 is running Ubuntu 11.10 (oneiric) on Linux kernel 3.16. So, I did the following.
Begin
  1. Connect a keyboard and mouse to motherboard
  2. After full bootup, press CTRL+ALT+F2 to get a login prompt
  3. Login with user: ubuntu/digital
Enable SSH
  1. sudo service ssh start
  2. sudo update-rc.d ssh defaults
  3. Disconnect keyboard/mouse and remote ssh
Update apt repositories
  1. clean up
  2. sudo apt-get clean
  3. sudo apt-get autoremove
Install correct APT repositories
  1. sudo nano /etc/apt/sources.list
  2. deb Index of /ubuntu oneiric main restricted universe multiverse
  3. deb Index of /ubuntu oneiric-updates main restricted universe multiverse
  4. deb Index of /ubuntu oneiric-security main restricted universe multiverse
Install NTP
  1. sudo apt-get install ntp
  2. sudo nano /etc/ntp.conf
  3. set server to pool.ntp.org
Install NTP service
  1. sudo update-rc.d ntp start 20 2 3 4 5 . stop 20 1 .
  2. sudo service ntp status
Set NTP Timezone:
  1. sudo dpkg-reconfigure tzdata
  2. sudo service ntp restart
Change Hostname
  1. sudo nano /etc/hostname
  2. sudo nano /etc/hosts
Install htop
  1. sudo apt-get install htop
