Listen to Main LR of MTR recording (via USB channel)
After i recorded a multitrack recording on SD card, with the Main LR channels, i’d like to listen to the recorded Main LR only. This is not possible now. Could be via the USB input for example (as an option) so there is no need for an extra channel.
I have a workaround for this:
  • On the CONFIG - USB/SD page, on the Channel Assignment:
  • Set 19/20 to Main LR.
  • Arm 19/20 and disarm Main LR (or choose something else for the stereo LR)
When playback a multitrack recording the Main LR mix recording, which is recorded on channels 19/20, can be heard on the USB input.
NB This is the same for a DAW mix return.
