live T112 and idr32 Network Dante
Hi everyone! I am having a bit of frustration to change the IP addresses of my IDR32 and T112 surface and Touchscreen: When the system in default configuration everything is working fine, but as soon as I try to change the IP addresses of surface, Touchscreen and IDR the surface and Touchscreen connect but the IDR isn’t able to connect…
I did respect the same Logic in moving them from ip family 1 to family 0 but it does not seem to work. SO if their IP are 192.168.1.1 for IDR and 192.168.1.2 for surface and 192.168.1.3 for touchscreen is all good (default settings) but if I change them to 192.168.0.1 and so on the IDR does not connect… what am I doing it wrong?
Did you reboot the iDR after changing its IP?
https://support.allen-heath.com/hc/en-gb/articles/4404771634705-iLive-Reset-network-address
