Live Trax remote controlled by SQ5
Sorry for my question, but I am new to Live Trax in combination with SQ5. Recording and Playback works great including channel names. My question is it possible to start Trax recording via SQ screen tabs remotely? Tried everything unfortunately without sucsess.
I don’t know if this is possible. If so, it would probably require establishing a MIDI connection between the SQ and computer using A&H MIDI Control, then getting LiveTrax MIDI connection to talk to MIDI Control. If all of that works, you can almost certainly set up a soft key on the SQ to start recording.
@ivothamm - As you have the channel names working, I believe you have a MIDI connection established and should therefore be able to use the controls on the Utility->General->MIDI screen, or assign ‘MMC’ (MIDI Machine Controls) to SoftKeys to achieve this.
If not, please contact us directly through support.allen-heath.com
