Local Monitor Output on R-72
I was sitting in a seperate room for mixing a theater show last friday.
I guess it’s there but I have no idea where I can change the volume for my local monitor out on the R-72…
SRV-AVB
R-72, iDR-16, xDR-16
Can you assign it a different matrix send (identical to your main mix)?
iDR32 mixrack
MixRack for iPad & Tweak for iPhone apps
Asus N61 Laptop (x2 wireless) with Belkin PlayMax N600 HD router
Sennheiser IEM (for PFL)
Dante card (soon!)
The matrix was that what I used, but it would be better to have PFL as well on the same outputs. If I use a matrix this isn’t the case.
SRV-AVB
Ah, tricky - I’ll have to defer to someone who uses a console in that case :wink:
iDR32 mixrack
Dante card (soon!)
You could try using the stereo PAFL wedge outputs. If you assign wedge L and R out of the R72 outputs, then you can assign the wedge channel onto the surface and use it as a volume control.
Andy
Using the Wedge Outputs wasn’t an option in this special case, because there was no possibility for reconfiguring the desk to turn processing on wedge on.
Without processing the wedge out didn’t contain the Main signal as expected.
Maybe David, Carey or Rob can give me a hint… :smiley:
SRV-AVB
In the PAFL setup screen you can set levels for the main mix to PAFL. This affects the level when no PAFL buttons are selected. That may do what you’re asking for if you want the main mix all the time. It wouldn’t be quickly adjustable as you set the level for each output separately. The inf. settings turns them off. Otherwise you may have to assign a fader/s for wedge monitors as suggested. Page 13 in the PDF getting started guide.
P.S. There’s always the level knob on the amp powering your monitors. [:wink: ]
Scott
iDR 32
iDR D-Out
MMO
Lenova T61, M90, iPad soon I hope.
quote:
Genelec 8020 over 1,5m away… to difficult
I assigned the wedge fader but there was no Left/Right signal only PFL.
Should I activate the processing in the Wedges to have the main always present?
That is the only thing I hadn’t done so far.
SRV-AVB
No, you shouldn’t need to activate processing to have mains present when nothing is PAFL’d.
Are you sure you’ve got the mains configured to go to PAFL? You’ll find these options in the PAFL menu. And just ensure mains isn’t muted/DCA muted.
AndyH
Nothing is shure in this case, stress level was to high on friday…
Will it test tomorrow
SRV-AVB
The wedge fader changes not the volume of the local monitor output. So I can’t see any chance to change the volume on that?
SRV-AVB
da du einen deutschen Namen führts hoff ich einen User aus Germany gefunden zu haben.Ich bekomme in 10 Tagen meine Ilive T112 inkl.iDRack 48,habe die deutsche Kuzanleitung vom deutschen Vertrieb erhalten,da ich aber im Digital Mixerbereich am Anfang bin,würde ich mich über eine Hilfe sehr freuen.
Beste Grüße Micha TOP 40 Band Spirit
I’am a new user,in the next 10 days I buy a Ilive T112…I surch a user from germany,Austria,for example…
You can set up the Pre Fader Listening to After Fader Listening with just 1 click, there are 2 buttons left next to the “mains” faders. then, when you have After Fader Listening in your PAFL, you will hear the sound after the fader. :smiley:
iDR 48
T112
waiting for iPad2
and M-Dante
Nobody is listening to me…
My Surface is not T-112, or T-80 it’s R-72 and it has different buttons and it misses the local monitor volume poti.
That is the problem.
SRV-AVB
quote:
Originally posted by Bricasti
Ein deutsches Forum ist hier zu finden: https://www.iliveuser.de/index.php
For the english speaking… above is a link to a german user forum dedicated to the iLive system.
SRV-AVB
Hi Steffenromeiss,
You said “The wedge fader changes not the volume of the local monitor output”. Yes that is correct, I said in my first post that you must use “the stereo PAFL wedge outputs. Assign wedge L and R out of the R72 outputs”. Then you can assign the wedge volume control/fader anywhere on the surface (in several different places if you like) to adjust your PAFL/monitor volume.
Unfortunately there is no volume control on the R72 for the Local Monitor Outputs. You have to use a different monitor output if you require a volume control on the board, such as the Wedge monitor.
AndyH
quote:
So why is there no volume control? Don’t get the point in this.
Was it a space issue in the surface design?
Is it possible to add one?
SRV-AVB
