Logic Control App (in development)
I have been developing my own app and wanted to post about it to gauge interest. And hopefully get some ideas from the community.
The concept: Similar to how companion works but mostly built around Dlive. The app monitors a huge variety of trigger inputs. Many from Dlive but also have Shure wireless, Dante, Companion, and Qlab working.
These triggers can then be put thru a logic (if desired). Think… if all or any of these values are true then continue. This includes live Dlive values as well as the other devices I mentioned. Along with timecode (MTC/LTC) and time of day/week variables. Many of those variables have above, below and range values.
Once triggered and passes variables you can assign actions. Just one or many if desired.
Many of the control points are not included in the MIDI documentation but was able to reverse engineer many of them. Metering was the big break thru! The app can use metering data as triggers and variables.
I am curious about the communities interest in this kind of app. And would love to know what control related applications people have yet been able to solve that this app might be able to do.
Control Examples:
  1. When Shure battery threshold goes below 20%, alternate input color between green/red. Stop flash when PFL is selected.
  2. When metering level is above -60db on TB input flash lights on surface
  3. When BGM level travels below -70db mute channel
Have at it
JV
That are fantastic ideas, should be available natively. Trigger stuff via metering would be super handy.
This would be fantastic additions to what A&H does not like to give into our hands. And would be so helpful for productive work with dLive.
I am on a surface-less setup and am always looking for ways to control the console the way I like/need. There where made certain trigger additions to firmware 2.1, many of those rely on a connected surface, though. I have found ways to trick the system and trigger these commands from within companion or via midi. But none of these ways are documented or tested and are therefor not supported by A&H.
The ticket I opened to clarify if these ways are working by accident or are “ok” the way I use them is open for 4 months now, without getting a assumption by support.
That might shed some light on how interested they are to further improve controllability of the dLive system?
So big thumbs up to the effort you are putting into this !!!
Cool! I wish this sort of thing was built-in so we wouldn’t need another computer for it.
Sounds impressive. I think there are a lot of things dLive users might want to do that are not exposed by official interfaces.
I’d absolutely love this app. Would it work with sending midi signals to dLive? I’d need it to trigger actions. If it does, I will buy. And happy to be a beta tester if needs be, this is incredibly powerful. Especially that Shure battery warning? I NEED THAT.
I already have the actions recall working in beta.
