In the market for a new digital mixer to replace my two dated 02Rs, so I´ve got some newbie questions:
Serious hobbyist, but no business attached. No Mics, synths only. Line signals, but with analog gems: I want to get the analog touch into the DAW at optimum quality. Electronic Music, dance, techno, ambient with a ton of fx, modulations and permanent changes in the sound sculpture. Does it make sense to look at a console that is optimized for live use? If that is the case of course.
Are the ins and outs freely assignable? So that I can start using channels by function (“Kick, Snare, Hihat”) instead of device connected (“Synth 1, Sampler 1, DAW channel 17”)? I currently have all sound sources on the desk, but would only need a selection of them per song… It would be much nicer to just work on the function instead of remembering which device/fader is handling, say, the bassline in that part of the song. You get the idea.
As scenes seem to include routing settings, how fast can they be switched and is there any impact on audio? I make heavy use of scene changes, as in : bar 1-16 scene a, bar 17-20 scene b, bar 21-24 scene a again etc. triggered via MIDI sequencer or launchpad pro. I need scene changes to be spot on and be able to switch at least per bar with a solid timing and no outages/artefacts. While switching parameters is not a concern, I´m not so sure about routing. So when ch1 is my bassline and this is from an analog synth during the verse but should be replaced by a vsti via dante during the breaks, will that work?
When switching scenes, how do the effects (insert and bus) behave? Will a delay be cut off and be replaced or will it keep delaying, but not process new material (I guess most likely not, maybe on the bus).
Got some 48kHz outboards like fireworx and others. Would you prefer to a) run at 96kHz and replace those boxes by newer models/DAW plugins or b) stay at 48kHz and throw in some of those ADAT/spdif/AES connected boxes to take some load off the DAW? I´m aware of the SQ internal effects
Extending for more channels could mean a second SQ or stageboxes (but in studio use). Pros Cons except the obvious (more faders)?
Overall, which DAW is integrated best? I wouldn´t mind getting my head around a 3rd program (plus license), if the integration is so much better for a certain software than for Reaper and Live, which I currently use. Wouldn´t mind to add Cubase for example.
How well can you handle DAW plugins with the SQ hardware? I´ve seen the MIDI layers but wonder if that makes for a real good integration. Not a showstopper, I could always opt in for a “real” controller sitting next to the SQ, but it would be nice to be able to choose.
Lots of Q, hope I find some answers here :).
