Looking for suggestions for FX settings
I’m a lifetime musician, but brand new to the 20B and digital mixing. Can anyone share their FX preferences and settings? I typically use a hall reverb and tight delay to fatten up vocals, but in tinkering with the options, I haven’t found a combination that makes me say, “That’s it!”
Any suggestions?
The only reverb that works for me in the 20b is “Space Verb Plates” Use the control tab to set the FX level to “0” db, then set the FX level to “LR mains” to “0” db. Next switch to the “sends to” tab that allows fader control of the “wet/dry” mix.
Back in the control tab select “Trails off”
FX is the weakest element in the CQ20b, however these are the settings that I have found that work fairly well for acoustic Bluegrass music.
Hugh
I’m surprised to see Trails Off as a suggestion - normally these would want to be left on so that if the FX gets muted (or needs to be muted) it doesn’t just cut out abruptly and fades nicely off.
For Spaceverb, you’ve not mentioned some key aspects -
What decay time are you using?
What space do you have selected?
And do you have any of the FX Assist buttons pressed?
Finally, have you sculpted your FX sound with the FX PEQ at all?
You will have to find the settings that suit your specific needs while mine work for me , they may not be the best for you: Do your own!
Hugh
Thank you for your suggestions. Space verb was one that I was playing around with.
I also use spaceverb as my main verb. I agree with the above, and not trying to be snarky, but just use your ears!
This is what works for me:
• mains get a combo of echoverb + chorus on vox, ezverb on instruments
• aux feeds, ezverb really low. just enough to not sound dry but not drenched.
Thank SO much for your input and photos!
