Hello. We recently got a T112/48 setup (running version 1.80, didn’t want to update til after Easter) and so far it has been fantastic. However at the last two Easter practices the surface and mixrack has lost connection. When I first set it up, do to timing constraints I hadn’t ran the Cat5 cable through the ceiling. How it was ran wasn’t really an issue as no one normally is around it. But with the Easter drama people were walking around by it. I thought maybe it had been stepped on and damaged or something. So got a new cable and routed it through the ceiling out of the way. Last night everything was working perfectly. I was tweaking, saving adjustments, we were almost to the end and again the surface lost connection.
I have a wi-fi router hooked up to the mixrack and my laptop for a backup. However I had the laptop hooked up to the surface at the time as I find somethings easier to do with the laptop. Anyways I turned on my wifi and tried to connect to the mixrack and it wouldn’t connect. In retrospect I think it was because I was trying to connect to mixrack + surface. Should I have just tried connecting to the mixrack? Or could it be my router causing issues? It’s a Linksys WRT150N.
Because after re-booting the surface, and it working again, my laptop wouldn’t connect through wi-fi to the mixrack or Cat5 straight to the surface. That is until I manually set my IP address and connected straight to the surface. I had also disconnected the router by then just to make sure it wasn’t messing with things.
What is my best plan of action to not lose control again? The Drama is multiple songs with people on multiple levels. Some songs to backing tracks, some with a live band. And some scenes are just action with a backing track and no mics open. So I have scenes set for each part. If I get stuck in a scene that is only the backing track I’m kinda up a creek without paddle. However as long as I can get connected and be able to select scenes everything should be pretty close. I’m open to suggestions.
Now that I’m thinking about it I have a spare cat5 cable ran from the mixrack to the FOH. I am planning on using it for DANTE. Would running it from the mixrack to my laptop be the best plan? Seems as though it might be. But again. Any help is greatly appreciated.
And if I haven’t mentioned it, the first performance is in about 9 hours. Thanks. ![]()
T112/48, MacBook Pro, Mac Mini, and trying to patiently wait on Dante. ![]()
