In order to meet national and some local laws on noise and safety we need a better way to measure SPL vs the dBFS on the Qu.
Whilst we could use handheld meters that is not a viable solution.
We need a box that would sense the true SPL short medium and long term and relay that to the Qu and display it next to the dBFS meters. Make it adjustable as LUFs is not the best solution.
Mixing for NPR TV and similar places can be handled with the dBFS shown but for venues where actual SPL is regulated we need a better way to do it. But knowing the actual LUFs as being measured could save with editing efforts to adjust things later.
This would best be located in the audience which is the protected class by the laws. SPL levels on stage and in the balcony would differ too much to use placed there.
Perhaps if performers cared about their ears there could be another box designed (or the same one with different feature enabled) so they could dial in the loudness they wanted and not have to guess at it. Or maybe they dont really care about protecting their ears? Anyway the law requires us to protect the listeners in the audience so one device is needed to help automate that.
But using the measurement to ensure that the law is met would never be illegal no matter how that feedback loop got closed in the USA and most of the world with sensible governments, maybe in some that tend to being very controlling.
Even if it not to conform with the law, a way to tell the actual loudness level in the audience and a way to use it to control the mixer would be useful.
Automatic feedback suppressors already provide such a control albeit limited and in a crude manner.
stop being an obnoxious bully
you are not the police for this website nor even a moderator just a kibitzer
my suggestion has everything to do with AH products to fix a need that is essential
if you dont like my posts then dont read them
but please stop with your useless comments meant only to disparage something else because you need to do that to feel better about yourself
I could not leave them uncommented because somebody who reads them could think it’s right what you are saying
sound pressure level measurement is not meaningful inside a closed electrical environment…
there is no sound inside…
just electricity or bits and bytes
you can’t measure what’s not there
and there are a lot of solutions to measure real sound pressure level already available
and they have to be calibrated since uncalibrated measurement equipment is… not correct
to calibrate the system and to handle the information is the responsibility of the sound technician
and still has nothing to do with Qu series mixing desks in general
to discuss SPL measurement solutions there are better places on the internet…
Drawmer and I’m sure others already make good brick wall limiters that you can set
the threshold in relation to the room spl. One model of theirs has green, yellow and red
stop light metering so you know when your getting close.
True SPL monitoring by the numbers is done by handheld meters and standalone software.
Not something that needs to be part of the mixer.
That said I think there was a mixer that did run SMAART or something like it.
Churches really need a way to match dBFS on the Qu vs dBSPL they measure so they can easily set proper levels.
We have used handheld meters but that does not help us set the levels without them which would be ideal.
They also take away from doing other tasks which complicates things.
Not PART of the mixer but part of the AH SYSTEM so we can see visually where we are at.
You totally misread what I said.
The SPL level is in the room that the audience complains about when it is too low/high.
The mixer has a meter with dBFS matching the signal in the room based on the power amp settings.
We need to match the dBSPL in the room with the dBFS shown on the mixer.
The power amp has been set. It will never be changed.
All changes will come from the Qu.
But we do need a way to match Qu signal levels with SPL levels automatically in RT.
Why do you go out of your way to try to find a problem with what I post?
I am a degreed engineer and also licensed Professional Engineer.
I know what I am posting is just fine even if you dont like it.
If you do not like my suggestion then ignore it. Why do you get so worked up over my posts anyway.
[I know your real reason but will not post it so Keith wont censor yet another message]
Calibration is just another of your red herrings. Of course it would need calibration. That is not an issue.
You claim you comment because my posts are wrong but you mostly complained that I should not make suggestions to improve the AH gear. Inconsistency would make me wonder why [except that I know your problem]
Some of your comments make me think you think I am dumber than a box of rocks.
But they do show a lot about you and your character while not impacting my suggestions at all.
if you mean you have to adapt the volume in the room to the level meter in the QU
then ok… do it with your brain
it’s loud enough at -3dB on the meter of the QU here you go… go with everything to -3dB
and set a master limiter at -3dB and leave the master fader at 0
→ Loudness measured in LUFS has nothing to do with the acoustic environment. And also the scale of the Qu cannot show LUFS.
→ SPL Metering has to be measured in the Room. And it will change when people (absorbing material) is in the Room - so if the room is empty your SPL will be higher, because the room will reflect more, instead of absorbing the soundenergy.
SPL can be measured weighted, fast, slow, impuls. But there’s no long- nor short-term SPL! It can be integrated to an LA,eq over a time interval.
→ the dB Scale is also something else.
So I think the title of the thread is wrong - you want to measure SPL to get a maximum LA,eq isn’t it?
So it’s a maximum Soundpressure Level - not Loudness.
But I don’t now what the American Law is about. Maybe you can give us European the info
greetings
That’s more or less what the Drawmer units I mentioned do.
What if there’s a loud guitar (or whatever) on stage?
You turn that channel down don’t you. Now that signal’s not contributing as much to the sound going through the desk, so the desk’s metering will be lower.
So do you now turn up the levels on the desk to maintain your desired level? No! So this built in meter is useless.
You need to measure SPL with a mic in the room, as what’s going through the desk is never everything that’s contributing to sound levels.
For rough guidance, there are some cheap/free phone apps that are pretty good, and basic sound level meters don’t cost a lot.
(For anybody in UK, and possibly beyond, Lidl have some for £10 at the moment, though I don’t know if they’re any good)
Our metering would be at the LR out to the power amp showing dBFS level.
The power amp is fixed.
The dBSPL would be where the audience is.
The LR dBFS would be a combination of all mikes in use.
Some performers can be so loud acoustically that I have no way to lower them effectively.
And usually there is no need to do that. The normal situation for us is usually to raise low level orators/singers.
And on some occasions they have their own amp/speakers on stage which we cannot control.
The piano mikes are pretty well set and they perform quite consistently.
The Organ is acoustic with its own sound and is usually the loudest sound when the organist cranks it up.
Perfection is not possible. But we would like to do the best we can do ourselves and do it consistently.
