Been watching so many vids by now that I am kinda losing it.
Is the XVive good enough? 4 people band, like to keep cost low or let’s say reliable and good quality but as low cost as those two previous words would bear ![]()
Let me know what you suggest.
Singer, drummer, bassist and guitarist. Have option to route DI, drums have trigger system, can also go with a PZM mic, guitar amp has DI speaker emulated out.
There are many reviews of Xvive IEMs on YouTube, Look out for Scott Uhl On that platform.
There has been a healthy debate about the use of IEMs on the Basschat forum, search for the IEM Bible thread at basschat.co.uk.
I have not used Xvive Myself Butt they use the same frequency as Wi-Fi for their wireless devices and they are digital transmission. This means that there is inherently a delay sometimes called latency That may or may not cause you a problem. You will see wild claims around the Internet about how much latency is too much and many claim they can hear one millisecond. In my case, I’m happy with anything up to about 10 ms and from memory most of the far eastern digital wireless devices are in the 3 to 6 mS Range for latency.
You can of course use a UHF system that will have minimal or no latency, although these tend to use compansion. This is where the signal is compressed for transmission and decompressed or expanded at the receiver end. Either way the best quality systems cost.
I’m sure others will chime in with their experience but in the end you must decide yourself which criteria works for you.
One thing that I will advise though is to consider how many channels you need. Many devices, especially those working on the shared frequencies, both digital and UHF have a limited number of simultaneous channels available.
The best low cost IEM solution is always going to be a wired solution. Something like the Behringer Powerplay P1 work great and are only $50 in the US currently (after Behringer’s recent price cuts). If you are honest with yourself, most musicians are stationary and don’t need a wireless system. Certainly drum and keyboard players are stationary, but even guitar and bass players tend to be stationary unless they also have wireless instrument connections. This leaves just the singer who legitimately might need a wireless system if they tend to jump around stage (and what singer doesn’t?).
So save money by going wired for all stationary players and then get a decent wireless system for anyone that really needs it. Just understand that decent means at least $1000 per stereo wireless setup.
There are no stationary players, we’re all over the place and even swap stage right with stage left for some songs with the bassist…ever our drummer moved quite a bit, but I guess he’s about the only one that can be put on wired headphones.
XVive is about 5ms…which might be good enough, although we do have a few 170bpm songs where the drummer plays super fast.
All WiFi has latency the more congested the frequency ether 2.4 or 5.8 it will raise. I been in the WiFi business sense 2005. Your best beat is to use an independent WiFi access point and not the built in system. Also get the router above all equipment to not block the WiFi signal very important for 5.8 to really run low latency.
For a wired IEM I would better go for a small analog mixer instead.
As from 70 bucks you have better control on you mix than with Beh.P1.
Alto TrueMix500 or even better Mackie Mix8.
How would a small Analogue mixer help? You have 6 Aux outputs on the CQ18/20 which are in effect mixers in their own right. Using a P1 type device makes thing simple.
P1 and other similar wired IEM system are just a 2 channels phone level amplifier that convert 2 balanced input to a unbalance (stereo) Output.
Little mixer like for example a Xenyx 802S do the same plus a 3 band eq.
If you have already such a small mixer in your rig and for more static case, where you don’t need to wear your IEM system, just the earplug, why not use it ?
On stage, running while performing in metal band?
“P1 and other similar wired IEM system are just a 2 channels phone level amplifier that convert 2 balanced input to a unbalance (stereo) Output.”
Correct. They take the aux output from the CQ (or any other console) and increase it’s voltage to a level that is compatible with headphones. The “small analog mixer” is not required when you use the aux outputs of the CQ (or any other mixer). Musicians can “mix” their aux levels with the CQ4You app. Basically the end result is exactly what you are suggesting, but without all the extra hardware or wiring requirements (I mean how do you plan on getting inputs into the small analog mixer AND the CQ???)
Technically since I have some older mixer I can use them as headphone amps if I want to run cables…at the same time, discrete one user rechargeable headphone amp is about $30 but still needs to run cables.
The Xvive system on the other hand can do with one transmitter and 4 receivers and provide wireless mix for everybody…so that seems the way to go!
@Brian CQ4You - how’s that? Do I need to assign who can use it or???
“CQ4You – how’s that? Do I need to assign who can use it or???”
Users select which aux they want to control. It’s possible that someone could select the wrong aux and end up changing someone elses IEM, but it is usually discovered and corrected very quickly - because none of the changes they are making on the app are changing what they hear, and some one else is yelling “Who’s messing with my mix!” ![]()
Hello.
I need stereo wired IEM.
I am working on a very cheap stereo wired solution, based on the Behringer HA400.
-CQ Aux1 and Aux2 stereo linked
-Hot signal form Aux1 (Tip) goes to Tip of stereo Jack headphone
-Hot signal from Aux2 (Tip) goes to Ring of stereo Jack headphone
-Ring of the Aux1 and Aux2 are unused
-GND to GND as normal.
It work just fine.
I have designed a little PCB to have a more efficient and easy little box.
AUX1 and Aux2 from to CQ goes via XLR to this box, then you connect the HA400 to the output of this box.
It required only 3 XRL to stereo jack adapter.
You can share up to 4 time this mix via headphone with individual volume control.
Ended up getting a little Mackie headphone preamp box. Running Aux1+2 locked in stereo, sounds pretty good, the band is happy. Running wired with Beyerdynamic DT770 headphones, drummer has Vic Firth cancelling headphones and is happy as well.
I have used the xvive u4 for monitoring with 4 member band but i was the only one who was using the xvive u4 but we were using it with a different wireless mixer which created some signal interference, as the xvive uses 2.4 ghz, changing it to different channel did solve the issue at that time. Also xvive does not do the automatic channel selection you might get away with selecting different channel manually if there is interference. Sound wise i will say it is a good mono signal. If you want another wireless system which is cheaper then you can look into NUX B-7PSM, i believe it uses 5.8ghz, it might be better. i have seen some good reviews in the internet but never used it. and i believe it does auto selection of the clean channel if there is any interference. I believe it is about $199 in amazon which is similar priced with xvive u4. i was also looking into the Phenyx Pro Wireless in-Ear Monitor System. see if you can find reviews on that as well and it is a stereo monitoring system.
Or you can always put drummer in a wired mix and rest of the band use wireless systems. this way you will have less device in the bandwidth.
Wireless mics, IEM systems, if they operate in any of the WIFI bands it’s just a matter of when not if they will have drop out issues.
Thanks, will look at that one as well!
