M-Dante audio glitches?
Anyone else have this issue? Multi tracked a practice the other day onto an 8 core amd with 16gb ram and heaps of space and all through the recording there’s errors and get cracks and pops? how should i have this set up? i even pushed the buffer out to 2048 samples to try and smooth it but no luck. is this something to do with clock settings?
Yes, check the clock settings. Most likely the GLD and DVS aren’t synchronising properly.
The way we have it setup, make sure that in Dante Controller under device view that the brklyn module is set as slave to external word clock. Then, the GLD itself should be set as ‘preferred master’ in Settings.
George is right.
here is the same with some expanded dialogue:
https://iliveforum.allen-heath.com/topic.asp?TOPIC_ID=2745
Bob
GLD80, AR2412, 2xAR84, Dante, GLD Remote
Did this, still experiencing, not as much but still there
quote:
Make sure you do both:
Using Dante Controller under Network View → Clock Status, I set the m-Dante as Preferred master, and Slave to external word clock ‘Yes’ (i.e. slave m_Dante to iLive, sort of counter intuitive?)
Bob
Could someone put up some screen shots of what dvs and the controller should look like, as far as i can tell im doing it right but still ending up with un usable material
I had this same issue. To use more than 32 channels, you must have a gigabit ethernet card on your computer. Most computers have only 100mb/s card, which will cause the pops that you are describing. Like I said, I had the EXACT same issue, and fought with the settings for a month before trying one last thing. I bought a $15 gigabit ethernet card and installed into my computer. Now I have flawless recordings, quicker setup and routing with the new card.
Shaun
Already using gigabit, I built a pc especially for it, looks like this
amd fx8320
gigabyte ga990fxa
16gb ddr3 ram
2tb hdd
radeon hd7750
I’ve been disabling the wifi and everything
Is there anything in the network such as a ethernet switch that isnt gigabit? The Dante is supposed to work in an existing network, but just to be safe, I have my computer directly connected to the Dante, separate from the outside network, thus eliminating any possible issues there. However, my PC does have wifi and it is connected to the outside network, and I still haven’t had issues there.
Shaun
Nope i run cat 6 straight from gigabit port to dante module. I’m positive its something to do with setup as the tracks record but don’t sync, audio seems to jump around. is it possible its to do with the buffer sample size?
I also had issues with the onboard NIC on our PC just because it was fairly cheap and nasty.
Bought one of these: https://www.intel.com/content/www/us/en/network-adapters/gigabit-network-adapters/gigabit-ct-desktop-adapter.html
All seems OK now. Perhaps something to consider if you’re using an onboard NIC.
We have recorded probably 16+ hours of Live material and tested for another 8 hours from 12 to 50 channels into Reaper without a single glitch. I have done this both through a switch (most of the hours using it) and without a switch.
Originally I had to work through the correct clock settings (described earlier). Somewhere you have a clocking issue. Make sure yo have the correct settings on the recording application too.
Bob
