Mac to QU32 over usb for playback and streaming
I’d be so grateful if someone can tell me whether this is possible?
I plugged in the mixer and have managed to send audio into OBS on my mac just fine.
The qu32 shows up as a possible audio output - I’d like to be able to send audio back the other way but not from a daw, just from our proclaim presentation software and itunes. But how to route / map the channel to a fader?
The online guides I’ve found seem to be only for sending multitrack and it looks like you have to set the whole desk to usb? I just want to send a stereo mix from the mac.
I found some instructions which worked so sharing:
First, you’ll need to set the Global USB source to USB B. You can do this by selecting any channel, pressing the Processing button, then pressing the Fn button underneath the screen to access the Source Page. Tap your finger on the global USB source to change it.
Next, you’ll need to set your return channels. You can do this by using the Preamp screen and the Source Page (where the Global USB source is set) to assign specific channels.
On the mac go to audio midi setup, select your qu-32 Audio. Go to the output tab, you can’t seem to adjust volumes. Click configure speakers, and select your channels in there.
