tuejo
2 September 2013 14:38
1
Hi.
I need to run in and out via madi on a DigiCo mixer. In the madi card manual it says that it will read both 56 and 64 channel protocol but will it change the transmit to 56 channel when it gets that in? Has anyone done I/O madi with a DigiCo mixer?
BR Tue.
tuejo
2 September 2013 20:30
2
I can see under the FAQ that it says:
Q: Does M-MADI work with RME and other third party devices?
A: Yes, we have tested M-MADI and it works well with RME devices, however we recommend you update RME devices to the latest version of
firmware. We have customers who have happily used M-MADI with Digico 56-channel MADI streams. M-MADI can provide multi-channel I/O via
SSL or Avid interfaces to ProTools.
But! It also says that the out is always 64 channel mode? Can I run In AND Out of a DigiCo desk with madi from the Ilive?
Please help if you know!!
BR Tue
Digico MADI streams are 56 channel. So the ilive will change its setting to that many channels only.
You should be able to route between the consoles, but Digico will limit it to 56. It is not an iLive issue.
Gil Parente
Design & Integration
Atlantic Pro Audio, Inc.
Gparente@apa-ee.com
