- Longer Names for Inputs and Outputs
- more Input and Output Source Points in Config:
- MAIN (L or/and R), SD, USB Chan 17-24 (Move from “Config->USB/SD” to “Config->Output”)
- USB Source Point for every Channel (Move from “Config->USB/SD->Channel Assignment” to “Config-Input Channels”)
- Main Bus: To use Aux for delayed Main (Or can Select Output source for AUX from Main)
- Add input fields for all parameters to enter values with keyboard
- Doubleclick on Fader goes to 0dB
- Support larger SDCARDs than 32 GB
- More than 2 MixPad-Clients over WLAN
- Copy input-channel with all Settings to another channel
(direct way, is possible over “Config->Input->libray-save”, “library->load” to other channel) - Use actual Date/Time from Windows/Android for saved files on SDCARD
Updated:
128 GB SDCARD works (8 h 16 Min recording time at 48 khz)
- Source Points can be changed while recording.
→ Would be good to add a popup box with info that recording is active and extra confirmation for all configuration options while recording. - “Config->USB/SD->Channel Assignment”:
If I select “ST1 IN” only “ST IN” will be displayed
If I select “ST2 IN” only “ST2” will be displayed
I found two bugs in “Config-Input”:
→ multiselect: If I select all inputs and try to select ST1 and ST2 only one of ST is selected, but the change of the input ist not done at the selected ST.
→ link stereo: if I select a channel in the mid of the input rows and klick “Stereo link”, the selection jumps to the beginning of the row.
Not really a bug but irritating.
