Main LR mix is not independent from other mix outs
I’m using a QU 24. Mix 1 is sent USB for live stream, mix 2 is a stage monitor mix. I’ve noticed changes in my main mix also affects my live stream mix, and monitor mix. How do I make these independent from each other?
You need at least set the mixes pre fader.
Select the mix with the blue buttons, select the mix master and then hold the pre button on the left.
The select buttons of the channels indicate pre or post setting.
To change all sends at once, press the select in the master mix again while holding the pre button.
Thank you for the reply! I assed there was an obvious solution to my problem, and that was the issue. After some tinkering yesterday I stumbled into the solution. Thanks again!
