Make LR Mix Select flash when using sends on faders
I’m new to the SQ having taken delivery a week ago, although I have used SQ6 previously at local venues. I can’t be the only person that has adjusted, what I thought was the main mix, only to realise that I was changing (i.e completely messing up) a monitor or FX mix!
I wondered how the console could warn the user that they’re using Sends-on-Faders, and I think either of these could work:
  1. Whenever a mix other than LR is selected, the LR Mix button could flash, maybe not even blue.
  2. Alternatively, the scribble strips could invert (go light-on-dark).
Either of these would instantly alert that SOF is active. What d’ya think?
Cheers,
Pete Alcock.
To be honest, there are already indicators for send on faders, if you ignore them you will ignore the others as well.
If you are on sends on faders, the corresponding mix button will be lit.
And the master fader mix button indicator is off.
It changes to red if you assigned the listen level to it.
Hi Steffen, I take your point, but the FX mix buttons for example, light up blue which is very easily missed. I don’t think it’s a case of ignoring them, more a fact of not noticing them.
To illustrate the point, try settling a soft key to be global tap tempo. The thing stands out like a beacon - there’s no way you’ll not notice that! (So much so that I had to remove that function from the soft key as it was annoying). That’s the level of prominence I was in a S.O.F. light.
I think everyone has been in this awkward situation at some point.
So I can well understand and support the desire for an option of a better indicaton for SOF.
Alternatively, I could imagine the following too:
We would have an option to enable all mix buttons to have the same behavior as the talkback button (Momentary + Latch).
In this case would pressing and holding of a mix button activate SOF only temporarily for corrections to the chosen mix.
After releasing the button you are automatically back in the main mix.
Alternatively, you can also as until now permanently select a mix by short pressing the mix button.
I’m all for the most “rude” indicators that SoF is on, and don’t believe that the Bus LED is enough. Mixing Station can be configured so that all faders flash in inverted colour when SoF is active - that’s how I like it - not pretty, but dead clear what’s going on.
SQ using flashing LED strips would be a pretty good way to achieve this.
I completely agree that there needs to be a much more obvious “in-your-face” indication that sends on fader is active. I would prefer flashing LED’s on all channel strips, but at minimum keep the current selection flashing. I oversee a lot of volunteers and student workers who are just learning mixing/consoles/etc and I get a huge volume of calls related to this very issue. Seriously, at least half the time I get a call it is “the fader isn’t working… I turn it up but don’t hear anything…” - I believe I have asked for this in a previous post a year or so ago, but came back to the forums one more time to vent my frustration and hope that this makes it into a firmware update soon!
Seriously… Coming from Yamaha world (all channel select keys light up), to Soundcraft (all fader lightstrips change colors), to Digico (all channel screens change color and name)… I’m sure there are more examples out there - but it seems like A&H completely missed the ball on this simple but important piece of communication to the engineer.
Yes!
I think at the very least, the selected mix LED should blink (unless LR is selected).
Please don’t wish “the very least”!
In my opinion that wouldn’t be enough.
During a show, so much is flashing and moving and you’re focused on the center.
A light flashing on the right would definitely not be noticeable enough.
It is certainly difficult to find the right balance, because in addition to the dosage of effects and monitors,
there are also cases where you have to work normally on a mix level, so that a “storm of flashes” would be very disruptive.
An example of this would be a separate mix for a stream in addition to the sound system.
I have the idea, that the red-framed header on the screen flashes inverted - and perhaps the pink-framed one too (see picture).
That would be in the field of vision and relatively noticeable, but wouldn’t bother so much.
Alternatively, you would yet have to be able to switch to a “most rude” variant for jobs like open air in the sunshine. ))
And despite all this: I would love the variable talkback button functionality (see my post #114339 above).
les boutons des mix n’ont qu’une petite led, donc impossible de faire clignoter l’ensemble du bouton. Il y aurait peut être possibilité de revoir la fonction de la bande led de L’éclairage (revoir la programmation interne) et avoir la possibilité de mettre une couleur quand nous sommes sur LR et une autre quand nous sommes sur le mix (au choix de l’utiliseur dans les paramètres : Activité ou pas cette fonction, puis si activité, choisir une couleur pour LR et une couleur pour MIX).
I would love this feature since I have to focus on switching to different channels and layers a lot plus navigate a lot on screen having a flashing light on what mix is selected would help tremendously. please add this as a standard please.
Yes, I agree 100%.
More indication of sends on faders would be a big help, via either or both of the ways OP listed.
Or perhaps an overall change to the color of the scribble strips in sends on faders mode.
Ideally options for this could be chosen in the setup screen to match a user’s preferences.
I agree it should be more apparent when you’re in sends on faders mode. We’ve been caught a number of times controlling an aux thinking we were on the main mix (e.g. we go to an aux during sound check, get distracted or step away to answer a question, then come back and forget we had gone to an aux). It’s been 8+ months since migrating to an SQ, and this still bugs us.
We use a soft key tied to the main mix to illuminate when NOT in sends in faders mode, but ideally we could program it to do the opposite, e.g. flash or something when NOT on the main mix. It seems like that would be an easy, non-breaking way to improve this. If the soft key could flash bright white, and flash quickly, then that would catch the eye. Pressing the soft key would return to the main mix and then the soft key would no longer illuminate.
Perhaps changing the scribble strips is another option. Changing the colors might get complicated, but perhaps adding a flashing border around each channel is an idea. I also thought about flashing the select buttons, although I could see some users not liking this. Ideally, the behavior could be configured in preferences or turned off if some users find it distracting (e.g. for those who use the SQ as a dedicated monitor controller).
Other mixers from Yamaha and Soundcraft made it more obvious you’re in sends on faders mode, using multiple visual indicators spread across the console for redundancy instead of assuming the operator will notice a single indicator like the button LED on the SQ. Surely there is more that could be done on the SQ without having to change the hardware.
