MATRIX PRE-POST
When you choose MATRIX PRE, it should be PRE ALL (GEQ, DYN, EQ,…) and not only PRE FADER.
Eg1 : you want to record a MATRIX of the MAIN. Even if in PRE, it’s POST processing (EQ, GEQ,…) !
Eg2 : you want to use MATRIX to process the FOH, the EQ on the main are available for all the speakers (SUB!!!) !!
SO PLEASE, a real PRE
I didn’t know Matrix can be pre something, but if so - can’t you change via Routing button the point of connection such as for Aux?
ddff_lv
I think, we can’t change the point of connection for MATRIX.
And for me, MATRIX must be able PRE process. On MIDAS PRO SERIE, you can choose it and it’s wonderfull.
I remember good old times when matrix was hard post. That’s why I never do any processing on busses being part of matrix. I can have as much matrixes as I need, so all processing goes there.
By the way- for a long time in Midas Pro series you couldn’t change the signal point of pre-fade aux, it was hard post EQ, which is no good. Don’t know if they fixed that.
ddff_lv
I’ve checked this out, and it seems to me that the Matrix receives its signal pre-processing. Example: If I’m using Delay speakers, I’ll send the Main outs to a Mono Matrix. Any EQ changes I make to the Mains don’t show up on the Matrix-they receive their signal before the Mains processing and so get a flat response, which is how it should be. I can then EQ and Delay the Matrix independently from the Mains.
-Mark
Will need to double check in the office but from the block diagram the Matrix is sourced post-processing (but pre-delay).
Easy work around is to put no processing on the main busses, then use more matrices to feed all your outputs/speakers including the mains. Then its only a problem if you run out of available busses.
on Midas, it’s sure it’s possible to choose Matrix pre or post processing.
I know we can use MATRIX to feed outputs and don’t use MAIN.
But it’s a workaround !
Why don’t put MATRIX PRE / POST process rather than just PRE / POST fader ?
