Does anybody have a label template they would share?
Thanks in advance!
Thanks in advance!
Hello,
Here is a template I created in Excel for my ME-1s.
Cory Maus
Generic-ME-1-Label-Template.xlsx (13.6 KB)
This is very helpful. Thanks!
Thanks, grabbed a copy too ![]()
Thanks! I grabbed this too.
Thank you for the template. This is a great asset to have.
Thank you!
Thanks, how are you applying this to the ME-1? Tape over, some type of sleeve, etc.
I just use a small piece of scotch tape on either end just to hold the strip in place.
Thank you! I will use it well.
Here is an adjusted template that can be laminated and then cut out. It has ears so that it does not need sticking to the ME-1. Each musician can have their own drop on labels for the buttons.
Generic-ME-1-Label-Template-_ASE.xlsx (13.3 KB)
I hate to talk about a different piece of gear but does anyone out there have a template or label solution for DX-168’s
Thank you!!!
You Rock, thanks for the template!
This is very helpful, Thanks
https://www.thavertech.com/website-designing-company-in-faridabad
Great idea! The laminated template with ears for easy attachment to the ME-1, along with personalized drop-on labels, sounds convenient.
Thanks for the template, very helpful.
Here is one that we use. It is meant to be printed out and laminated. It has lugs so that it will be a temporary fit on the unit. The user can adapt it to their personal scene and take the strip home for the next time. At the left had end is a reminder as to how to select different scenes. Scene 1 is our standard and scene 16 is the one we use for live streaming, when we feed the sound signal via an ME-1.
