ME-1 Not passing audio.
I have just setup my system daisy chaining 3 ME1’s from my Qu32 directly. (I Have also tried connecting from the AR2412.)
Either way I have been able to setup the channels on the ME they receive the channel names from the console but no audio is passed to the ME. However I am receiving the ST3 audio.
Is there a setting in the QU I should be changing?
A couple of things to check:
The ME1s will be getting signal from the DO point on the channels. Check position of the DO point in the signal chain (it’s movable.) If it was set to post-fader and all your channels’ faders were down, that would explain it.
Also check if the “follow mute” setting is engaged. If it is and your channels are muted, that would explain it.
