ME-1 not showing some channels
We have a dLive C3500, DM64 rack, ME-U and 5 ME-1 units. We have about 25+ channels patched to the ME-1 without any issues. We have recently added 7 lines of Ableton inputs and for some reason not all the channels are showing up on the Me-1.
The channels have been added to the surface layer then patched via the I/O > Outputs > MixRack (Output Sockets) > ME > IP Direct Out. The patch for Ableton starts at ME output 28, 29, 30, etc… out of the 7 new inputs only 4 are showing up on the ME-1. I see they are patched on the surface because the box is greyed out. What would be the reason for this? I had this once before but eventually the channel showed up after about 5mins. In this case with the Ableton the 4 inputs showed up instantly. I have restarted the console, unplugged the Me-1 and still nothing. Waited about 30mins and still nothing. Any advise on how I can solve this issue?
Hi Rupert
Does the audio from these channels come through to the ME-1? Are these channels set to ‘use received name’ in the ME-U web interface?
  • Jeff, A&H
Yes audio does pass through it’s just some inputs are not showing up for some odd reason. I patched 7 lines to the ME-1 out of the 7 only 4 are showing up. Regarding ME-U web interface where would I look to set the "use received name’?
Hi Rupert
In the ME-U web page, click ‘Channel Setup’, and you should see a table that has a ‘Use Received’ column. If you want the channel names to be passed through from the desk directly, all the boxes in this column should be ticked.
Hope this helps.
  • Jeff
