I have been trying to find a part number for a switch for the ME-1 system for a GLD. Has anyone had any success with anything? I tried a Cisco SG300 and could not get rid of the clicks. I am not an IT expert so something that worked with a simple set-up would be appreciated. The ME-U is not available for a couple months yet.
I suspect your switch may have an option to “un-manage” If it does, select that. The clicks usually mean the switch (or other equip) and GLD are not in synch. The switch may be trying to be the master…I am not sure.
I have no problems using an unmanaged switch with POE for my ME-1’s.
I have tried to “un-manage” the switch without success. Which switch are you using? I am happy to swap out hardware if I can find a solid recommendation for the new switch.
Do you guys know what the total POE power availability is for the Zyxel switch is? I just bought and Allied Telesis for around $400 which is a layer 2 switch but it has 95 watts total power for POE. If it can do around that I may sell my Allied Telesis and I could get a few of those Zyxels!
Gary
The Zyxel will do 120W, enough to power 8. I’m using it that way and it works great.
Gary
Awesome thanks. Just ordered that Zyxel one and will try it out. Will send that other switch back and it will pay for more than half of another ME1 which is what I am going to do.
re: cisco SG300 & ME1, these work amazingly well - if you know what to disable.
i have 4 me1’s and the monitor link on a vlan since i am also running some dante devices.
there are many parameters to disable as already detailed by the A&H support documents (stp, qos, etc), but you’ll still have to find a few more to be entirely click free. the two remaining things to look at are the following:
make sure your vlan port memebers are untagged, if you’re on a vlan.
disable LLDP discovery and CDP discovery. they can be found in the web gui under the administration tab.
after that, plus A&H’s requirements, you should be good to go!
