ME Stereo Channel Issue
Hey guys,
I have a weird issue. My system is DLive S7000/DM64. Driving ME system off the DM64. I set several channels to stereo linked (Keys, Tracks, etc). On my ME-1, instead of a single channel, it shows two of the same channel (assuming left/right).
The weirdness is that when i set the system up, the stereo link worked correctly and only showed one stereo name (ie Keys1) on the ME-1 network patch. Now it shows “Keys1” twice.
I reset the ME-U to default settings and started over but got the same issue.
Any tips would be helpful.
What does the ME-U see in terms of stereo link? You should be able to see this in its channel setup web page.
  • Jeff, A&H
It see’s one channel labeled Keys1 L and one channel labeled Keys1 R. Then the ME1 sees “Keys1” twice
If the ME output has its stereo link set in the dLive, the ME-U should show it looking like this:
If not, are you sure that the output is stereo linked in the ME tab of the I/O screen?
  • Jeff, A&H
Thanks Jeff. I have the stereo link option checked. Where your photo shows just “Keys” centered between 19-20, mine shows Keys on both 19 and 20.
Maybe I should reset my ME-U to default and start over.
Jarron
Here is a screenshot of mine
It doesn’t look like the ME outputs are set to stereo. If you touch one of the numbered squares along the top row of the 1-40 ME outputs page, it should bring up a box like this, where you can turn ‘Stereo Link’ on. If this is set up correctly, then I’m afraid I am out of ideas, and you’ll need to contact tech support.
Hope this helps.
  • Jeff, A&H
Thanks for this information. I never knew. Is this the same set up with the SQ consoles? I’ve been dealing with this issue for a long time.
