I could not find a definitive answer, any way to route the ME1 to route audio to IEM…such as through a DX012?
The MEs are designed to be located next to the musician so they can use the physical ME interface to adjust their “mix.” As such, it has stereo outputs designed to be used with headphones/IEM.
If you want to use board I/O for IEM, just use an aux send on the board and skip the ME system altogether.
Just connect your ME-1 output with the IEM Transmitter Input and you have a wireless IE System you can control with the ME-1.
ME-1 is a receive only device on the DSnake bus, hence cannot send anything anywhere. I can only receive the 40 channels allocated to it by the main mixer.
Yes, you can use the TRS stereo output from the ME-1 as line input to your IEM. See page 15 in the manual for cable :
I use 1/4" TRS-TRS cables to connect the ME-1 to a TRS patch panel on our IEM rack.
