Hi, How do you have your Avantis set to send to the Me1? We send pre-everything except for the input gain. Wondering if post would be better? TIA!
There isn’t a right or wrong answer. It simply depends on what works best for your situation. Certainly you can make an argument for sending it post EQ if your room is EQ’d well so that channel EQ is simply corrective for the source and not trying to correct something in the room.
How can I change the ME-1 to be post instead of pre-everything? I’m using an Avantis with several ME-1s.
Global direct out source, if you use the direct outs as sends to the ME’s.
Thanks Steffen. Could you explain in a bit more detail where I can find this on the avantis? Which tab / menu should I look for?
Routing screen, top right.
