We have the Avantis along with a number of ME500s. The issue I have is that outputs 14 and 15 cannot be selected on the ME500. That is to say the volume dots do not appear for those outputs like on outputs 1-13. Note: no IP channels are assigned to output 16.
The issue is with all MEs.
There are IP channels assigned to the ME outputs 14 and 15 on the I/O page.
We do not ever adjust the Ip Direct Out of the channels; so I have no reason to believe this would be set to -Inf dB.
I have confirmed the IP channels are not a part of a stereo pair i.e. IPs are set to Mono on the Setup → Config → Input Stereo screen.
I loaded another scene (one the scene being used is based on) and ME outputs 14 and 15 work as expected.
I have not yet tried moving the IP channels from outputs 14/15 to other working outputs, but that is the plan, hoping they work, as the band really needs the instruments in those IP channels in their ears.
I would appreciate any other suggestions for troubleshooting or thoughts as to what the issue could be.
Thank you
Paul
