Meters not Matching in bank and processing views
The meters on my Avantis are very inconsistent. If I look at the meter in each channel at the bottom of the screen and then click on a processing page for a channel, the page shows the meters in the yellow and yet on the bank view at the bottom of the screen, the meter is barely even showing (like a very weak signal). This doesn’t happen all the time or on every channel, but trying to set gains can be difficult when it does occur. Any easy answers??? Is there a way to reset?
If you go to the settings for Audio/Metering, you can reset the parameters there. Perhaps something got changed off of default at some point.
I did that. Reset everything twice. No change.
