MEU
Hi
Does anyone know if the MEU can be used as a standard switch in an iLive network. ie can I connect non ME1 devices into it and access the iLive, other devices on the network and ALL dante channels?
I’m looking at getting a couple of these
which need POE and I wondered if I could just run them off an MEU instead of having to buy another POE switch as well.
Regards
Toby
The bigger question is: do you really want to run the risk that the band will lose their IEMs even momentarily,for the sake of buying an extra $100 switch?
Duncan Whitcombe
@Dnxmirrorsounds
Mirror Sounds & metrochurch
Perth, Australia
T112, iDR48x2
www.mirrorsounds.com.au
www.metrochurch.org.au
Hi Toby
No, you can’t use the ME-U in that way. The 10 ports do form a standard switch, but all 10 broadcast a dSnake stream, which uses pretty much all of the bandwidth available.
  • Jeff, A&H
Thanks Jeff
@Duncan
If you can tell me where I can find a 16 or 24 port rack mount managed gigabit switch with POE for $100 then I wouldn’t need to ask.
The last switch I bought cost me $1800 so I was thinking if an MEU could be used it would nicely kill two birds with one stone.
Or one bird with two rack spaces so to speak.
I wouldn’t trust my audio to a $100 switch.
I’d rather not have to tell a client that the reason they had a 5000 pax riot on their hands when the audio stopped during a show was because I bought a $100 network switch which all of my control, audio and monitor splits for the whole show were passing through.
A switch is a single point of failure these days and not worth skimping on. There is a big difference between a cheap consumer switch and an enterprise managed switch which we really all should be using if we value the traffic passing over it.
Hi Toby,
Why not just add a POE injector to power the unit?
Sounds like it would be a $30 solution
Gil Parente
Design & Integration
Entertainment Arts, Inc.
iLive 176, T112
iDR48 , iDR16, iDR10
Multiple iPads
Dante
Etc…
I use POE a lot.
I have multiple access points, remote audio transmission equipment.
Injectors are ok, but they are messy and another point of failure.
quote:
Yes indeed - there is a big difference - a $100 switch could potentially fail and ruin your gig, an $1800 enterprise class managed switch could possibly fail and ruin your gig. The difference is $1700 and a false sense of security HaHaHa!! [:smiley: ]
Cheers
Richard Howey
Audio Dynamite Ltd
If that was the case I would have bought an x32 :smiley:
I have a pile of 5 poked dlink and net gear “cheap” switches that are broke.
I have had precisely zero Cisco and linksys switches out of a fleet of 7 that have failed.
I like those odds.
