My vocal channel is in the left side of my in ear mix even when I take it out or mute it. The same with the second vocal mix except it’s in my right side. I even unpatched it from the board and it was still in my mix. It’s not coming thru any other channels and it’s not doing it in any other mixes. The mic is patched directly to channel 1 on the console and my mix is outputs 1/2. Anyone have any thoughts??
Hi Jordan,
If you press the Sel key of the mix and then the Processing key, can you make sure the Mix External In Source Select is set to Unassigned?
Alex
