Hi there, i have the midi control software for mac working perfectly fine and then i also installed on it on a windows machine as i need two different machines to be able to send messages and control the board.
On the windows machine i can install it, select avantis, select tcp, it finds the avantis, i check the connect box and it shows connected.
However the midi port i expect to be created and available is not there. I tried using midi viewer app and another app to find it but its not there.
Has anyone received an answer on this? The ports were created OK for me (Windows 11) previously but with the new Windows 11 MIDI stack, I don’t see the MIDI control ports being created.
