Hi everyone
since i bought my Sq7 last week I am still setting up things for Studio use. So far most Problems i had could be solved… My newest now is the Midi setup for the Faders. in My Daw (cubase 9.5) its a pure mess… I have the latest Daw Control on my Mac Pro… In Cubase all 4 times i have set a Mackie Control with each the Daw Control ports 1-4 … So far so good… The Faders react on Sq7 and revers in the DAW… but not those where i expect… OK I then assigned the Midi 1-32 Strips inside the Sq7 diffrent so that the desired fader moves in the DAW example: IP01 is not Midi1 but Midi25 and soon… Ok i thought its like that and could live with it. When i had then almost all Strip given its diffrent non logic Midi number and almost all of the 32 Faders were reacting… I saw that not all Fader can be assigned for what ever reason and some Midi channels are simply not working to assign to… The next day when I loaded cubase again then even the Channels that i had to set where not controlling the right faders anymore… i was tweaking the right Midi strips again and after a restart they were again diffrent … Ok i was reading that on each new session after a restart the Mackie Controls have to get connected again manually … thats then ok but i can’t imagine that also the Midi Channels are changed again as well and those have to get reassigned again as well with diffrent channels… What am i doing wrong here? Does anyone experience the same problem ?
Also the possibility to rename an assigned Midi Channel is impossible… wich is sad because now i end up to glue a tape over the console to write the (if then working) channel on it… I wanted to buy at first a QU series console but because of the possibility to give a channel a name on those small LED screens was the reason why i bought an SQ7 and again the reason why i changed from a presonus console to this SQ7 beauty was the DAW control Possibility wich seems now a little be messed up … But as i saw that others here in the forum are using it as DAW control as well gives me hope that I am the one who is doing mistakes only and be teached on how to do it right… Thank you for all help ![]()
