Attempted to automate my CQ20 & EchoVerb to dynamically set the delay remotely via MIDI. Unfortunately I ran into all sorts of issues and MIDI limitations with the CQ series that was unexpected.
The delay can only be set via Tap Tempo. And only if assigned to a soft-key.
To get back to a fixed delay I needed to reload a FX or Scene.
Unable to load saved FX via MIDI; only the entire Scene available.
When loading a Scene, unable to mask Main output or anything. So I have to reset rig volume and gain settings for show.
Unable to turn Mute groups ON/Off via MIDI. Forces use of limited softkeys.
Didn’t expect to run into all these issues & limitations, as a half baked MIDI implementation was not on my Bingo card.
I will need to investigate this as a possible solution to one of my issues. TY. I have my PI already connected via WIFI & MIDI both isolated to my CQ20. If there is anything that can help when I prompt AI please share.
Not sure but ask something about converting incoming midi (from the app that send the tempo) into TCP frame that will be send to the CQ.
i am not at home now but will provide the TCP frame for the delay tempo asap.
Got it, thanks for any help with prompts. I have a basic softkeys python script working via TCP, but setting the tap tempo is being elusive. Need to find the specific NRPN LSB parameter address byte assigned to EchoVerb’s (FX slot 2) delay
