Midi output from Dlive
Hi, Trying to create a custom control app to fire specific cues in Qlab, I’ve got the daw remote working and using the Mute sting I can trigger Qlab however that mutes a channel on the Dlive. anyone tips on unique midi codes I can use to fire Specific cues in Qlab?
You can assign Midi notes for each cue within QLab, if you like. More info about that here…
Very aware of that. My issue is getting the midi out of the custom control app. The only notes I can get to work also mute channels on the Dlive
there is a document on the knowledge base that covers pretty everything MIDI related on dLive
ok it’s not on the knowledge base
just under documents
https://www.allen-heath.com/media/dLive-MIDI-TCP-Protocol-1.50.pdf
