In my band, I end up being the sound guy, the lead singer and lead guitar player. My hands are pretty full. I have a MIDI foot controller sending messages to my AxeFX digital guitar modeler.
What I’m wondering is if there might be a way to set up a MIDI send to the Qu-16, too, such that when I went from song A (where I have the lead and my vocal is a little hotter than the others) to song B (where I’m a background and need to bump someone else up in volume) I can do that with the same patch change that I’m using on my AxeFX?
Trouble is, there is no direct MIDI input on the Qu. And I can find lots of adapters that take USB in to MIDI out, but not the other way 'round.
I am in the process of having our techie build a foot switch that sends a midi string over TCP/iP to mute the internal fx, the pedal would plug in to the network port on the rear. He has already put a demo pedal together that only moves a single fader just to check that the pedal and desk were able to talk to one another.
So I would assume altering the pedal to do what you’re after wouldn’t be much of an issue.
Interesting. So it would basically be able to relay CC messages and so forth through the TCP/IP port? Does it have a standard MIDI in port on it? Are you marketing this?
The only downside to using such a pedal is that at the moment the QU series will only allow one device via the network port, so you wouldn’t be able to use an iPad. Hopefully in the future multiple devices will be allowed.
There will be hopefully a limited number of around 6 being made to gauge interest, more would be made if it was economically viable.
The Qu Series do not have a standard MIDI DIN Connector but they send and receive MIDI messages via the USB-B connector on the back of the board. If your guitar FX has a thru port, you could probably send messages to the mixer.
As stated above, if you tie up your network port with MIDI, you cannot use an iPad. One other thing. Using the TCP/IP port for MIDI (at least with a computer) requires special drivers.
Not problem with drivers using the pedal my techie has built, plug in and wait 30s or so for both the device and QU to handshake and away you go. Simple!!!
