Midi Scene Recall -> Go function
Hi all,
is there a known program change to trigger the “Go” function in scenes rather than a specific scene recall?
Currently when I recall a specific scene, the recall completes but doesn’t change the current or last recalled scene…
e.g.: Scene 1 is active, I recall scene 2 by midi and would like to recall scene 3 manually again,
the current scene will be scene 1 and I would trigger 2…
Having a midi program change linking the “Go” function would solve this…
Or am I doing something wrong?
My midi to recall a specific scene: BB 00 00 CB 03
Thanks a million!
Stijn
Hi, in the scene setup try selecting auto increment…and see if that helps.
Ray
Great thinking Ray, but unfortunately that doesn’t do the trick.
(I have it enabled by default actually :))
Alas, this is also not currently in the midi spec. (Pan is also missing, boooooooo.) One workaround you could do is use something like live professor’s cue lists, map dLive scenes to cues, then map next/previous/go out to whatever controller you’re trying to map for this function. I’m doing this with an ElGato Stream deck, which seems to be working quite smoothly.
